    Maybe I'm confusin the tip hitting the the earth and clogging thetip to the point it welds the wire to the copper tip?
    http://www.screwfix.com/prods/30030/...IG-Welder-150A
    I guess the only way to find out is to use the thing.
    Quote Originally Posted by GeorgeD View Post
    Good idea.
    One thing with these cheap welder they never tell you is about a thing called duty cycle.
    Duty Cycle is how long you can use it at what setting. Look on the plate at the rear and it should give you some figures as a percentage.
    The adverts says 150 amps but Screwflicks blurb says 140 amps for this model ?
    So just guessing it will say something like 70 A @ 100%
    90A at 80%
    110A @ 60%
    120A @ 40%
    140A @20%
    What this means is that the % figure is based on 10 minutes, so at 70A you can weld all day and at 140A it's weld 2 minutes, rest for 8.
    For obvious reasons they don't make a big fuss of this. The more you pay the higher the figures.
    John S -
  1. Vibration, mass and massive arguments
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 03-11-2014, 11:24 PM
  2. Bloody hell Lee's at it again.
    By John S in forum General Discussion
    Last Post: 19-12-2013, 04:53 PM
  3. What the hell do I need ?? (humourous replies expected :-) )
    By alboy in forum Marketplace Discussion
    Last Post: 08-09-2013, 12:42 PM
  4. Machine tool transporters that will move machines into position
    By komatias in forum Marketplace Discussion
    Last Post: 09-08-2013, 07:27 AM
  5. Mig or ARC Welder... What should i go for?
    By AdCNC in forum Welding, Brazing & Equipment
    Last Post: 08-12-2011, 02:01 PM
