Re: Newing Hall Millgrav (Apex Controller)
Pars
Hi just found your post on a random google search, did you get anywhere with this? I spent about 10 years programing and running this machine so should be able to help you. You state the old model I take it the machine is fitted with the older style square white control unit not the apex model? Have just registered on here so drop me a line if I can help in anyway I will.
If you do have the old control unit you can only program basic commands via G-codes for general milling purposes, if you wish to use it as an engraving machine you will need suitable software for your pc, I very much doubt the old newinghall software will be available, plus their dongles cost lots! I will see what information I can dig out on it its been a while.
I have spent many hours trying to get information about the Apex Controller which shows only two lines of text at once. What I cannot work out is how one sets up the controller to receive G-code. There are three formats, one being a Windows 'special' which works OK with JLS. However the more modern CNC software outputs G-code. Software purchased from BobCad USA was expensive, and from samples they wrote an interface using the information from Newing Hall which took months, but nobody seems to know how to select G-code for the interface. The Millgrav has new ball screws and is quite a nice machine, but the controller seems to let it down. I wonder if you would remember how to set it up for G-code. Cheers for any info you might have!
