    Oh by the way he has changed all of his tronics out for up to date stuff and is running Mach3
  2. Hi New Member ( name and address withheld ), i have gutted my machine as i was dismayed how BASIC the controller was, i felt that someone had found my old BBC basic computer and given it back to me to use again!!!
    I have so far rebuilt the z axis to use a Chinese water cooled spindle motor and inverter and therefore done away with the belt driven spindle and the very noisy motor mounted top central of the mill grav i have also stripped out all of the original electronics and i am currently building a PC mother board with a smooth stepper to give two IO ports and a serial port to control the inverter, i am intending to use one port to work with a MPG and the other port as limits and over travel switches all of this is to be run under windoz and Mach3 much to 2e0poz's dismay and his attempts for me to run Linux... i am stead fast with this windoz rubbish
    So far everything seems to be going to plan ( if i had one ) and i am now wiring and configuring the MB and all of the IO's.
    it is possible that i may be able to obtain some software for your apex controller..... but do not hold your breath, the chap i bought my machine from has another with the apex controller and my be willing to run off a copy, but he is an excellent engineer not a software wizz...!!
    I think your design building on a large surface table is an excellent idea, but impossible to move is it compleatly cancelled or will it fly again??
    Roger
  3. The Following User Says Thank You to cncezee For This Useful Post:
  4. #13
    Hi Roger
    Many Thanks for your reply, I am not fully sure if your machine had the Apex controller which you have removed or had the original electronics in the machine cabinet. I notice Newing Hall show Apex controllers on there current engraving machines but I understand them to be a later model.
    Re the "Table" engraver, I will probably keep the table and sell off the other components when I can get the MillGrav running.
    One idea I incorporated was to have the surface table long edge skirts machined parallel with a register so they could take ball slides. As a cost saving experiment I machined a flat bottomed 90deg vee groove centrally in a 80 x 20 flat this held a 30 x 30 square rail with the corner removed, held with recessed socked head screws at close centres. Essentially creating a bolt on adjustable vee guide. By shimming the upper and lower faces of the vee groove the rails could be adjusted parallel to the tables surface and to each other. Thats the theory but never put to the task. The gantry "saddle" was to be a machined vee with a 2mm PTFE "gasket" type gib strip. pre loaded again by shimming.
  5. Hi New Member ( name withheld ), i have spoke to my friend and he has asked what software you want>> also what controller you have, he describes it by the number of buttons along the top of the front panel. perhaps you can take a photo of it this would help greatly.
    Roger
  6. The Following User Says Thank You to cncezee For This Useful Post:
  7. my new Z
ID:	5844Click image for larger version.
Name:	IMG_2894 - Copy.gif
ID:	5845Click image for larger version.
ID:	5846Click image for larger version.
ID:	5847Click image for larger version.
ID:	5849Click image for larger version.
  8. The Following User Says Thank You to cncezee For This Useful Post:
  9. #16
    Quote Originally Posted by cncezee View Post
    Roger
    Hi
    This is the Apex controller fitted to my MillGrav any help you can offer would be very much appreciated.
  10. Hi New Member
    I am sorry to be the bearer of bad news but my friend john has been unable to find any of the software that came with his machine, he informas me that he never used it anyhow as he uses a really weird program called casemate this outputs a hpgl type of language and machines in layers and colours...way too weird for me and this prog is well locked up with dongles
    So perhaps you will go a similar rout to me......Wire cutters...................
    I have this weekend i have got the MPG ( manual pulse generator ) working and calibrated along with the spindle inverter working under Mach3, i will soon be fitting processing power back into the box on Millgrav..
    If you want any tips on how to do this i will be very happy to help
    RH
  11. #18
    jif's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 23-06-2017 Has been a member for 9-10 years. Has a total post count of 1.
    Hi there, Its nice to see a millgrav in good hands there. I worked at Newing-Hall as a fitter for 20 years and in that time I built or worked on just about every millgrav that we made. Its 10 years since the company went under but I think Pantograph Services of Leeds took over the handling of Newing-Halls affairs. I like the new spindle arrangment you have there, the large aluminium pulley on the original motor could sometimes cause trouble with vibration. The millgrav was one of my favourite machines because it did away with the old pantograph which could sometimes be difficult to set up and it was so easy to knock it out of square meaning a service call out to reset it. There were a couple of variations of the millgrav in that one had a solid aluminium plate holding the Y carriage and that had the slots for the ball blocks permanently machined at 90 deg to one another. The other had two aluminium plates on a spigot that allowed the two to swivel. We then had to manually set the plates at 90 deg to each other and dowel them with tapered pins. These machines were sold all over the world, The Jet Propulsion Lab USA (NASA) had one, Australia, South Africa, UK. Anyway, you will have to post some video footage of the machine working when its all up and running.
    Ian
  12. #19
    Quote Originally Posted by Pars View Post
    Hi just found your post on a random google search, did you get anywhere with this? I spent about 10 years programing and running this machine so should be able to help you. You state the old model I take it the machine is fitted with the older style square white control unit not the apex model? Have just registered on here so drop me a line if I can help in anyway I will.
    If you do have the old control unit you can only program basic commands via G-codes for general milling purposes, if you wish to use it as an engraving machine you will need suitable software for your pc, I very much doubt the old newinghall software will be available, plus their dongles cost lots! I will see what information I can dig out on it its been a while.
    I have spent many hours trying to get information about the Apex Controller which shows only two lines of text at once. What I cannot work out is how one sets up the controller to receive G-code. There are three formats, one being a Windows 'special' which works OK with JLS. However the more modern CNC software outputs G-code. Software purchased from BobCad USA was expensive, and from samples they wrote an interface using the information from Newing Hall which took months, but nobody seems to know how to select G-code for the interface. The Millgrav has new ball screws and is quite a nice machine, but the controller seems to let it down. I wonder if you would remember how to set it up for G-code. Cheers for any info you might have!
  13. #20
    Hi I am now the proud owner of a newing hall Millgrav, an older model but in beautiful condition, my question is about the controller and setting up, as there is no instructions to show how to use one of these machines, is there anyone out there in cnc land who may have some written instructions that they might want to share???
    I am not used to posting stuff, else I would paste the text in, but it appears that is not possible. The filr I wanted to send you is an RTF, so in order to send it I have renamed it with the extension PNG. If you actuall get this you need to copy the file and rename it to an RTF. The file is called JLS_FIRMWARE_INSTALL Good luck!
    No sorry, I can not see how to send this RTF, so contact me: - [email protected]
