2 Attachment(s)
		Denford Triac PC for sale
		Attachment 6456Attachment 6457
Fully enclosed Denford Triac PC for sale, converted to Mach3 and setup ready to work.
 Supplied with computer, keyboard, mouse and all leads.
Spindle is 30 int and has an easy change holder fitted.
£2200 ono.
Can be palletised or delivered at cost, or collected from CF11.
		Re: Denford Triac PC for sale
		A bargain, Better than the Boxford VMC by a long way in my opinion. Look at the way they have covered the Stepper, makes flood coolant a little less scarey, 30 int taper just to name two reasons, i wish i could afford it ....
		I'm tempted but just outside my budget....  and possibly the space available too...
		around £1500 I guess...  but I'd need to shift the MD30 as well to make space...
irving2008
 A bit low on that one, i could remove the mach conversion and get to £1900
Ricardoco
 if you wanted to run flood coolant on this machine it would be fine, the coolant version is physically the same except for the underslung tank.
		I am new to cnc of this type.
What was involved in the conversion to Mach?
how old is the machine? Does it show signs of wear on the bed, screws etc?
Do you have the spec or a link to it? Interested in x,y,z travel, spindle height from bed, motor size etc.
		Hi, here's a link to the denford website.
Denford Software & Machines • View forum - Triac
This machine has 300mm x axis, 180mm y axis, 235mm z axis. 1.5hp dc spindle 4000rpm.
It's a 1995 model i think, but don't let the age fool you, it has come from a school that barely used it. The condition is excellent and the quality is far better than the seig range of machines. This machine was £20,000 new, is extremely rigid and has no visible wear on any slide or ballscrew.
If you want a chat about it give me a ring on 07791011037 anytime.
		Just because Denford charged the school £20,000 for it doesn't mean to say it was ever worth that money.
All it means to say is someone saw them coming. A brand new Hass TM1 is still only £25,000 and that's a modern machining centre.
John S
Dear John,
I have just purchased said machine, chuffed to bits, £25k ? Was looking for a machine, not a mortgage.
Michael.
		If its still for sale, would go to £2000 on it, if in good condition. i presume it will mill stainless steel? Text me ASAP on 07507862221 if its still for sale and put mycncuk in the text!
		hi, this was sold several years ago.
i2i
 Hi, Do you have “baldor D281 motion control card for a triac P. C. (denford), red 7-segment LED display type. The firmware is ESMINT 3.28 V1.6H/S - JD5.”
