Re: belt on belt/servobelt
		Does that mean it acts like rack and pinion? G.
		Yes
http://bell-everman.com/products/lin...elt-linear-sbl
that is a link to the commercial version. belt stretch is limited to the amount of belt it takes to mesh with the bottom "rack" and go over the pinion so it should greatly improve a belt system. zero backlash apparently?
Kind of hoping someone else has done this  system and can warn me of the pitfalls ... but if not.. ill do it and report back.
		I built a prototype, but never tried it out. I decided to re-design it to be stronger and handle more power.
Ger21
 I am looking at using a servo-belt at the moment,  could you give any pointers as to how you designed this.
John
matthewb
I am erring towards a tractor belt small loop acting on a glued down base belt rather than 2 full length belts. Seems silly to use twice as much belt as i need.
 If it is a horizontal drive,  the full length belt is very good at keeping the base belt clean
John
johnsattuk
John
 Here are some pics
http://www.cnczone.com/forums/linear...tml#post933535
http://www.cnczone.com/forums/linear...tml#post934595
http://www.cnczone.com/forums/linear...tml#post969827
		What belt you would use? T5 or HTD5?
Have you considered to cast the belt on the frame side from epoxy resin?
		Would be nice if you could buy steel rack with T5 teeth,  perhaps stack some laser cut ones :cool:
		HTD5 won't work, it needs to be T5 to mesh with itself.
		Hypothetically,  If you were making a metal rack could you cut it to suit other belt sections
		apparently the Gates powerdrive profile works too
found this thread on cnczone.
I am going to glue the base belt down with double sided sticky tape (sailmakers version)
johnsattuk
John
 yes good point, im probably going to have the belt teeth vertical ..... probably... but that is yet to be decided 100% so.....
Ger21
 Thanks Ger21, i will look through at your system
Ger21
 agree on that but it zeems doable
https://www.youtube.com/watch?v=T9QU3YQe-Sc
		I'm pretty impressed with Mike Everman's Servo Belt concept.  I first ran across it in the threads on CNC zone Gerry refers to.  There more on it on Everman's own blog at http://mikeeverman.com/.  It seems like a great solution to the problems of belt stretch in conventional systems and the limited tooth engagement and resulting low shear strength and backlash  compensation I see in CNC fabric cutters like this: http://carlsondesign.com/plotter-cut...plotter-cutter.
What about making the belt on the drive motor side a continuous loop (tank tread) and skipping the full length top belt?  If you mount the belt system upside down, similar to how you see racks mounted on many CNC router axes, the protection from dust or chips seems unmerited.
Regards,
Chris Krumm
		6 Attachment(s)
tropostudio
Regards,
Chris Krumm
 Have been planning a moving table router and wanted to try a Servobelt design.  I had some Vexta 5 phase motors with 10-1 low backlash gearboxes which I wanted to use.  Wanted a sort of modular self contained drive that I could bolt onto the frame,  I shall be using a dual drive and will sync the drives with a shaft between the motors.
The std. 37mm OD bearings are assembled on steel tubes for alignment,  they act as spacers for the side frames and are clamped together by the mounting bolts
The engagement with the belt on the table, is set by the outer bolts in the chassis having slotted holes in the frame.  The belt tension is set by moving the motor in the slotted holes in the chassis plates,  also carries an outrigger bearing for the 18 tooth pinion.
I have carved a setup out of wood before I waste any aluminum  :concern:
		John,  did you ever build and use this servobelt tractor design?
		Unfortunately age and health got in the way so did not progress, still have all the bits.:shame:
		Age is no excuse....health well that is a tough one!    You are probably aware of it but Mike Everman has also produced and is selling a tractor style carriage now.    I am building a big vinyl cutter and will use the belt on belt system for X and Y.   Clearpath servos and Centroid's Acorn controller board.
