Thread: belt on belt/servobelt
I built a prototype, but never tried it out. I decided to re-design it to be stronger and handle more power.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
17-03-2015 #2
17-03-2015 #3
Gerry
The Following 2 Users Say Thank You to Ger21 For This Useful Post:
17-03-2015 #4
17-03-2015 #5
Would be nice if you could buy steel rack with T5 teeth, perhaps stack some laser cut ones
17-03-2015 #6
HTD5 won't work, it needs to be T5 to mesh with itself.
Gerry
17-03-2015 #7
Hypothetically, If you were making a metal rack could you cut it to suit other belt sections
17-03-2015 #8
agree on that but it zeems doable
https://www.youtube.com/watch?v=T9QU3YQe-Sc
14-05-2015 #9
I'm pretty impressed with Mike Everman's Servo Belt concept. I first ran across it in the threads on CNC zone Gerry refers to. There more on it on Everman's own blog at http://mikeeverman.com/. It seems like a great solution to the problems of belt stretch in conventional systems and the limited tooth engagement and resulting low shear strength and backlash compensation I see in CNC fabric cutters like this: http://carlsondesign.com/plotter-cut...plotter-cutter.
What about making the belt on the drive motor side a continuous loop (tank tread) and skipping the full length top belt? If you mount the belt system upside down, similar to how you see racks mounted on many CNC router axes, the protection from dust or chips seems unmerited.
Regards,
Chris KrummLast edited by tropostudio; 15-05-2015 at 03:50 PM.
Which Belt Profile
By manofgresley in forum Belt Drive, Pulleys & TimingReplies: 5Last Post: 27-09-2013, 12:54 PM -
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
Belt Driving your leadscrews !
By Lee Roberts in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 05-02-2011, 09:14 AM
