  1. #19
    Doddy's Avatar
    Lives in Preston, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 9-10 years. Has a total post count of 1,364. Received thanks 188 times, giving thanks to others 66 times. Referred 1 members to the community.
    Or use a NTC thermistor.
    BTW, that design - the resistor wattage values are wrong - if, as claimed, it's intended to limit the current to 5A then the resistors should be rated at 250W (P=I^2 x R). I'd also caution that C1 is specified at the limits of its operation - failure of that would result in the explosive failure of C2 C2 and likely destruction of R1 and RE1.
    Treat with care.
    Oh, you dissipate about 6W in that capacitor and relay.
    And A-Camera, electric shock isn't the only hazard of a charged capacitor. The biggest hazard at this potential are burns and physical injury resulting from a spontaneous reaction to a sudden discharge. You mention batteries - of course you don't use a bleed resistor on batteries - that's a divisive argument. But the first instruction in any vehicle maintenance manual is to remove the -V lead before any work. Why?
    Last edited by Doddy; 11-07-2018 at 07:21 PM. Reason: Why do I let myself get wound up
  1. need help! choosing right kit
    By msacnc in forum Gantry/Router Machines & Building
    Last Post: 17-09-2014, 09:41 AM
  2. Resistor Question
    By GTJim in forum General Electronics
    Last Post: 07-04-2013, 10:01 AM
  3. Resistor Calculator
    Last Post: 17-04-2012, 05:22 AM
  4. ATX power supply - load resistor - do I need one ?
    By rckeith in forum General Electronics
    Last Post: 18-08-2010, 03:21 PM
  5. What type of resistor?
    By Smiler in forum General Electronics
    Last Post: 05-12-2008, 10:04 PM
