Thread: Electrical product advice needed
Yes, but couldn't find a suitable one. The driver we are using on out test rig is this one http://www.ebay.co.uk/itm/2015292070...%3AMEBIDX%3AIT and it has CE marking and IP65 printed on it (???).
Can you buy one that is CE rated?
This might be a good read: http://www.meanwell.eu/ExclusivePDF/...OVALS-NOTE.pdfLast edited by Clive S; 02-09-2016 at 06:32 PM.
02-09-2016 #3
Rob,
I didn't make it clear but my reasoning for the thermal fuse is to use one rated above the temperature which the light unit might reach in a very warm room under normal operating conditions such that the power would cut before anything got hot enough to melt or burn,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
02-09-2016 #4
1. Thanks Clive, A right riveting read
Actually it may be relevant as the LED driver pictured on page 1 is the one (or very similar) we are using. I realise that CE could mean 'Chinese Equivalent'.
2. Yes Nick, I realised that. We still have tests to do to see temperature rises, but the LED is on a heatsink with plenty of free air (a fan would detract from the artistic aspects). As far as melting is concerned, I have no worries over the cast iron or bronze, but start to get a bit wary about the aluminium. My main concern is the driver and LED chip going pop in flames. There is a 20mm fuse holder which will be furnished with a 1A glass fuse.
No I am not being sarky! I am just knackered after a hard day watching my son do some grafting. I have just had to resort to painkillers (Bacardi and coke). Thanks mates, for taking onboard this issue and providing me with some meat to chew.
Cheers,
Rob
02-09-2016 #5
04-09-2016 #6
Here's some pics of the lamp base. Don't forget that is only a prototype to test the idea out, nowhere near a finished product, so if you see anything that needs to be changed, please say.
My desk isn't normally like that, I tidied it up to get some space to take the photos
Having looked through the photos, I can see one thing that needs attention - the mains wires input to the driver !
Cheers,
RobLast edited by cropwell; 04-09-2016 at 11:14 PM.
Rob I am not an expert But I would put some mica or other suitable material under the mains choc block so as to make sure no strands of wire will touch the ali base.
edit I don't see the frustation hammer on the tableLast edited by Clive S; 04-09-2016 at 11:20 PM.
04-09-2016 #8
You are right, the mains shrouding will have to be attended to. All things electrical have to be quadruple safe, just to protect yourself from twats. I hope the sculpture itself will be expensive enough for owners to keep brats with paper clips off it. But you k-never k-know. If people are daft enough to try and dry off a poodle in a microwave and then successfully sue because the manufacturers instructions didn't say not to, what hope is there for the intelligent world ?
TTFN
Rob
05-09-2016 #9
Why don't you show this to a local, CERTIFIED electrician and ask his/her opinion? It may cost £100-150 if you want a written report also, but can't be that expensive if you only wants an opinion. Anyway, it is money well worth spending if you have this as a serious business idea.
05-09-2016 #10
Most Part P sparkies are not only CERTIFIED but CERTIFIABLE. To get any valuable advice or opinion, I would have to go to the IEEE to find a suitable Electrical Engineer. The most sensible testing, at this stage, is PAT*, coupled with common safety sense. We know from experience in this forum, that errord are easily made, and often missed in review. It is like having a document proof read, you probably won't spot your own mistakes, but someone else sees them immediately because they go in with a different mindset.
If the idea of an underneath lit glass sculpture has any artistic appeal and serious commercial possibility, then we will go the whole hog with a CE driver and integral switched mains cable and a plug suitable for the destination country, and go for the IEEE cert, but that costs mega bucks.
Cheers,
Rob
* which we need to have done anyway, as the exhibitions won't accept anything plugged in, without a green sticker.
++ did you spot it ?
Advice needed on everything
By chrisjames in forum General DiscussionReplies: 12Last Post: 11-11-2015, 11:40 PM -
Advice needed on Amadeal
By croy in forum General DiscussionReplies: 13Last Post: 21-08-2015, 01:28 PM -
Quick Advice Needed - F&S
By Tenson in forum Tool & Tooling TechnologyReplies: 1Last Post: 01-01-2013, 06:38 PM -
Electrical whizz needed :)
By don_jarr in forum Motor Drivers & ControllersReplies: 22Last Post: 23-06-2012, 08:10 PM -
SPG X3 CNC Mill, advice needed please
By shaggyhawkings in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 07-01-2010, 11:00 PM
