Thread: gantry weight
11-09-2016 #6
Just to make sure my poor old brain is still working...
If you put a 1m radius pulley on a 3Nm motor
One rev gives you 3N over a distance of 2
meters
One rev on a 10mm screw only moves you 0.01m
so the force increases in proportion (3 x 2
) / 0.01 = 1885N force
1N will accelerate a 1kg mass at 1 m/s/s
So 1885N will accelerate a 132kg mass at 1885/132 = 14.2m/s/s
Sounds okay, 1G is 9.8m/s/s and 1G with a safety margin is good acceleration.
Also we know that 132kgf will accelerate a 132kg mass at 1G because that is what happens when you drop it.
So you get about 132kgf to drive the tool dead slow with the same margin.
How much weight can 3.1NM motor lift? (as in Z axis)
By Noplace in forum Stepper & Servo MotorsReplies: 2Last Post: 20-04-2016, 09:42 AM -
Z axis weight
By DigiSoft in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 15-09-2013, 07:42 PM -
Dimensions and Weight of Denford Starmill PC Please
By cristec in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-08-2012, 07:02 AM -
Sieg X2 head weight
By pequod in forum Sieg Milling MachinesReplies: 6Last Post: 25-08-2011, 11:09 PM
