Thread: Higher end Chinese controllers?
07-10-2016 #11
I'm well aware of mini-ITX boards, but you still need to make a control panel.
Ideally I'd just like to modify/make a housing, wire the controller in, bolt it in place, configure it, and be good to go.
The big thing is cost/time.
A good metal industrial panel mount keyboard with track pad/ball is around £200, a suitable resistive touchscreen monitor is another £200, then you have the cost of separate switches, which will probably be at least £50 for good quality ones, and say another £50 for assorted wiring/connectors to connect that lot up. That's £500 before you even consider the controller or PC, which means you can quite easily spent £1000 on the hardware. Then you still need the time to design it all, build it, and wire it up.
Admittedly, that's buying stuff new, and building a good industrial quality controller, which is overkill for most hobby users, but when you need the machine to make money, you have to consider the whole picture.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Comparing motion controllers...
By JW1977 in forum Control Hardware & SystemsReplies: 34Last Post: 17-02-2016, 02:36 PM -
Wiring Steppers to controllers
By liamo1991 in forum Motor Drivers & ControllersReplies: 1Last Post: 05-09-2013, 01:58 AM -
PCI Motion Controllers
By IanS1 in forum Motor Drivers & ControllersReplies: 0Last Post: 16-05-2013, 12:13 AM -
Difference between controllers and Cad/Cam programming???
By 0625272 in forum Computer SoftwareReplies: 0Last Post: 23-06-2011, 08:40 PM -
Programmable logic controllers
By cncezee in forum Motor Drivers & ControllersReplies: 12Last Post: 15-11-2010, 08:44 PM
