    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 89 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by urbansickness View Post
    Looking to purchase a small machine for personnel project use and for occasional use at work. Was looking at the OX cnc and Aspire software, the OX fits my budget but unsure of the Apsire software price. i use autocad for other work so learning similar software shouldnt be a problem
    Andy
    First welcome to the forum Andy. If you want to be cutting anything serious then I don't think the OX machine will do it .
    Have you thought about asking for a quotation from one of the forum members as there are one or two that make exceptional machines on here. Here is the section to do that. http://www.mycncuk.com/forums/196-MARKETPLACE
    You would need to state the cutting size that you require and what materials that you are likely to be cutting.
    Or you could build your own by starting a build log and then asking all the questions you want.
    On the software side, the Aspire software is great but not cheap. If you have access to AutoCAD and are happy to use it, then you could stick with that for a lot of CAD work. Instead of Aspire, you could buy Vectric vCarve Pro (very good for 2D and 2.5D work, especially for things like lettering and signwriting, as well as profiling and pocketing), and if you need to do genuine 3D work, you can use Vectric Cut3D to generate toolpaths and, if needed, use vCarve to drop them into a bigger design. vCarve looks as if it has very simple 2D CAD and CAM facilities but in practice these are capable of doing pretty much all that you are likely to need. Of course there are better tools, but the simplicity of use of the Vectric toolset is a big bonus. You can also mix-and-match - design in AutoCAD if you want, then export a DXF file into vCarve to do any final modifications and use vCarve to do the toolpath generation. Aspire does everything vCarve and Cut3D can do, better integrated into a single package, plus better CAD, but you don't necessarily need it. Download the trial editions and look for yourself. You might be saving a few hundred quid that could go towards a better machine!
    Looks like ill be researching a self build then, the price increase from the OX to more professional machines is quite steep so a self build seems to the way to.
    Ill be cutting all the material mentioned in my first post, size wise i probably wouldnt need to go any bigger than a work area of 1200 by 1000mm for the time being.
    Software wise i think ill have to wait until i sort out a machine then have a try on the free trials
    Thanks for your help
  1. NEW MEMBER: Yet another newbie
    By Clod341 in forum New Member Introductions
    Last Post: 22-05-2014, 07:00 PM
  2. NEW MEMBER: Another Newbie
    By Pintglass in forum New Member Introductions
    Last Post: 22-03-2014, 02:20 AM
  3. NEW MEMBER: Another newbie
    By Stuart Winsor in forum New Member Introductions
    Last Post: 16-01-2014, 12:15 PM
  4. NEW MEMBER: Hi there CNC Newbie
    By Jester in forum New Member Introductions
    Last Post: 04-01-2014, 08:22 PM
  5. NEW MEMBER: Newbie here
    By Mr Tim in forum New Member Introductions
    Last Post: 23-08-2011, 08:50 PM
