  1. #2
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,957. Received thanks 366 times, giving thanks to others 8 times.
    If you can't find a definitive answer, get a bit 10mm thick bar (width doesn't matter), clamp it in the turret like a tool, and see if what would be the cutting surface lines up with the chuck centreline. If it lines up, you need 10mm tools, if it doesn't, measure by how much it's away from the centreline.
    Personally, if it was designed to take 9mm tools, I'd remove the turret and machine each slot a mm lower, so I could use 10mm tooling.
    You'll struggle to get any 9mm tooling, whereas 10mm tooling is very common for hobby size lathes.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. Replacing the cuting tools on a Boxford TCL 160
    By Saracen in forum Boxford Lathes
    Last Post: 22-01-2016, 12:25 AM
  2. Boxford TCL160 turret operation
    Last Post: 22-10-2015, 11:58 AM
  3. Cutting PCB’s - recommendations, tools etc
    By Fivetide in forum Electronic Project Building
    Last Post: 22-07-2013, 01:23 PM
  4. Looking for Lathe Cutting Tools
    By Zeeshan in forum Tool & Tooling Technology
    Last Post: 06-09-2011, 09:50 AM
  5. UK Supplier of Cutting tools
    By Ccrewz in forum Tool & Tooling Technology
    Last Post: 03-02-2010, 11:32 AM
