Page 34 of 35 FirstFirst ... 2432333435 LastLast
  1. #331
    I forgot to mention that at AB882 controllers you have to leave the enable pins disconnected otherwise the servos won't start.
  2. #332
    I manage to see my steppers move for the very first time last night.
    Congrats Nick! Isn't it fantastic when things start moving?! Getting very close now!
    I think the drivers being enabled when disconnected is the default behavior. I changed mine in the protuner configuration software to need the enable signal in the opposite direction. My thoughts being that an active signal of "yes motor you can move" is better than "no signal means everything is okay" because if a wire got disconnected it fails into a safe state.
  3. #333
    That's a good point once again, I will do it that way.
    Thanks again!
  4. #334
    Thanks to @AndyUK who post his UCCNC set up at his building thread and to all the other guys in the forum, I manage to see my steppers move for the very first time last night.
    Thanks everyone for the support!
    Here is Andy's post:http://www.mycncuk.com/threads/11552...084#post126084
    How did I miss this.? Well done Nick and nice to see another machine come to life. Looking forward to the first cut video so crack on..
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  6. #335
    Thanks to all of you guys, much appreciated,thanks again
  7. #336
  8. #337
    I cut with my bandsaw the 20mm thick aluminum plate I bought from a scrap yard for 80 euros, to replace the MDF I use to mock up everything.
    Things went well.
ID:	30734Click image for larger version.
ID:	30735Click image for larger version.
ID:	30736Click image for larger version.
  9. #338
    What tap and bolts do you guys recommend for the Y axis plates?
    Happy new year to you and your families!
  10. #339
    Nope, that prize is mine! Though I've moved on a little since this video was made.
  11. The Following User Says Thank You to Kitwn For This Useful Post:
  12. #340
    I like it!
    It it some sort of steampunk!!!
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
