    Thanks Clive, I was looking for this video,it is from the first I see here at the forum, but couldn't recall who build it and took the video,I am getting old!
    Lives in Marple Stockport, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Not as old as me but if you need the list of part from Rapid https://www.rapidonline.com/NewProdu...rce=header-bar let me know.
  3. The Following 2 Users Say Thank You to Clive S For This Useful Post:
    Yes I would love to have it!!!
  5. #4
    OK
    1No. https://www.rapidonline.com/vigortro...-x-25v-88-0033
    some people use 24-24v secondary depends how high you mains voltage is. I don't know what your supply is? for the primary
    3 No. https://www.rapidonline.com/jianghai...-4khrs-59-6175
    3 No. https://www.rapidonline.com/lcr-ep08...-clamp-11-3004
    1 No. https://www.rapidonline.com/dc-compo...a-600v-47-1012
  6. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  7. #5
    Test your input before buying a coil
    220-240v you want ~50v output before rectified.
    240v-260v (I get 252v's in which is very high) get a 45v this will give you ~70v when rectified to DC.
    UK used to run at 240v and rest of EU at 220v but it was standardised almost 20 years ago at 230v in reality nothing changed because the leeway allowed on voltage meant that 240v systems fell into the acceptable performance. In Lithuania where the infrastructure has only recently been upgraded I got 230v but I noticed in Berlin I was getting 220v's as the infrastructure pre-dated the 230v regs.
    I would bet Nick falls into the 220v-240v zone.
    Get 2 rectifiers as they're £1 each too cheap not to have a spare even though they are super reliable, I managed to blow one up with transformer lol.
    At home my voltage is ~240v at work it's always over 250v so my theory is they are pumping higher voltages to industrial sites to compensate for the much higher inductive loads on the system.
  8. The Following User Says Thank You to Desertboy For This Useful Post:
  1. cnc 4axis hot wire mach3;
    By maikonesk in forum Hotwire Cutting Machines
    Last Post: 07-08-2015, 02:15 PM
