Thread: Help me choose my first spindle
11-05-2017 #1
Hi building a machine with 1/3 sheet of ply build area out of t slot extrusion with 25mm supported rail on 1 axis, hiwin on the other and Z will be 25mm smooth rod and 20mm ballscrew. Nema 23 powered.
A lot of what I will do is cutting/milling parts from mdf or aluminium to vac form from. Normally it will be MDF but occasionally Aluminium depending on the desired life span of the mold.
I need a spindle obviously but bit confused on what to buy? I want to cut ply, mdf & aluminium at a decent rate and the spindle will be worked 20-30 hours a week. I need something to get me working now and once I've done a couple of jobs for a customer I can afford to get a decent one from Zapp and keep the Chinese one as a spare.
1. I have no idea what sort of power I want, is it a case of more power quicker cutting?
2. From what I read on here it wants to be water cooled and that I should use my own water pump (I have loads), so I will go with water cooled this is 0 hassle to me.
3. Speed control, not sure what a VFD is some kind of power inverter I assume that performs PWM but what's the difference between a VFD and a spindle that supports PWM through Mach 3 (With appropriate circuitry)?
4. Collet size?
I was eyeing up this one
http://www.ebay.co.uk/itm/2-2KW-WATE...8AAOSw-W5Us1mz
The 4 german bearing thing most of they claim how true is it?
I'm guessing it's pot luck on quality.
My friend gave me a brand new router to fit but when he turned up with it I burst out laughing as it's one of these lol
https://www.ebay.co.uk/p/?iid=232188...&crdt=0&chn=ps
ThanksLast edited by Desertboy; 11-05-2017 at 09:36 AM.
Help me choose a mill.
By Fingerpuk in forum Milling Machines, Builds & ConversionsReplies: 12Last Post: 25-11-2016, 12:41 AM -
Which CNC Router to choose, and what are the costs
By Painted Letters in forum Machine DiscussionReplies: 5Last Post: 29-06-2016, 03:54 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
HELP:How to choose
By sinograver in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 17-10-2011, 02:00 AM -
How to choose a lead scew
By GTJim in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 15-02-2009, 12:30 PM
