  1. #10
    Hi Desertboy, your machine looks good, nice progress! I can now see why you did not tap the ends of the extrusion - what a f*cking nightmare! Fortunately KJN sent me two lengths of the incorrect extrusion that i quickly had a practice on, so the middle of the Extrusion is indeed a hole that is the correct size to tap an M12 thread in, HOWEVER as the diagram below, because the circle is within a square it makes it impossible to tap, once the thread has been cut into the circle material, it slips out and into the the 4 empty corners.
    I think i will do the same as you and drive the bolt in to get the thread... I'm worried now that there isn't enough meat there to provide a strong connection.
    In other news, my spindle kit, steppers, stepper drivers arrived. Just waiting on the PSU's, controller and some other little bits before i start mocking the machine up.
    Alex
  1. The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
    By Husky in forum Generic Chinese Spindles
    Last Post: 22-01-2021, 06:54 PM
  2. NEW MEMBER: new member building a cnc router
  3. Building a plasma table, need advice.
    By superclarkey in forum Plasma Table Machines
    Last Post: 20-09-2016, 04:57 PM
  4. NEW MEMBER: Newbie seeking CNC info for guitar building
    By rusty999 in forum New Member Introductions
    Last Post: 15-01-2016, 02:26 PM
  5. Building a hybrid CNC mill. Need advice and recommendations
