Thread: Temperamental spindle
Hi gentlemen,
thanks for all the posts.
Apologies for me taking my time, I've used the router a few times since last post, and all seemed well, until today- when it's back with a vengeance.
It took four attempts but the spindle came to life, however it stopped- without cause after 2 mins.
Once again I'm having to wait- I believe this may be a clue to the issue- the fact I have to wait several hours until the spindle will run again. This is the original VFD, installed by dean. routerCNC, in regards to your question about the behaviour of the spindle when FOR and DCM were connected, technically it didn't power the spindle up- however, I would say it was successful as it made a 'click' - something the VFD has always done- Dean told me this was something in the VFD to do with acceleration, and from day 1 it's always been a little coy at starting up at very slow (sub 6krpm) or very fast (over 20k) speeds, usually taking a few attempts, though it's never been a big deal. I assume short circuiting it in that way makes it power up to full speed, at which point it does what it would have always done, and clicks(think this click would be a MCB?) and prevents the spindle from running.
This isn't what is happening at the moment- I hit the spindle button on mach3 and it's totally unresponsive, the VFD sits there happily blinking away, no MCB noise, no power to the spindle.
I know it's a bit confusing, hope I've at least done an ok job of explaining it :(Last edited by mark84; 09-09-2017 at 01:27 PM.
09-09-2017 #2
The vfd settings:
Pd5-400
Pd4-400
Pd3-200.01
Pd6-002.50
Pd7-0.50
Pd8-220
Pd9-015.0
Pd11-01.20
Pd14-0.3
Pd15-1.0
Pd72-400
Pd143-05.0
Pd142-5.0
Pd144-3000
Thanks so much :)
10-09-2017 #3
Pd 143 should be set to 2 its hard to believe it ever started with this set to 5
Pd 3 set to 400
Pd 11 I would set to 55 so that the lowest spindle speed would be about 3300
Pd 14 set to 2
Pd 15 set to 2
Pd 7 set to 1.5
Pd 142 set to 7 (if 2.2kw)
Try these and report backLast edited by Clive S; 10-09-2017 at 10:48 AM.
10-09-2017 #4
Thank you, Clive. It'll be a few days, but I'll keep you informed.
14-09-2017 #5
I've used the router for an hour with no issue, thank you very much for all the replies, especially you, Clive. I'm not quite sure what happened but I'm (fairly!) confident in saying I'm back in business :D couldn't have done it without this forum!
14-09-2017 #6
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
