12-10-2017 #2
13-10-2017 #3
13-10-2017 #4
Read over more epoxy-related posts before pouring and came across the one by Boyan Sylvaski discussing shrinkage of centered bridge causing distortion in the middles of the rails! Well, I wasn't tearing it down and starting over. So, I did the pour, gave it time to flow out, and then blocked the bridge entrances with razor blades:
Used a heat gun multiple times to get rid of bubbles. I was surprised at how well that worked. You could see the bubbles pop and disappear as you waved the heat gun over. Top looks like glass at this point.
Wallace
18-10-2017 #5
Pulled forms off today. Not sure if this was because I used the Totalboat epoxy, but I was surprised at the size of the meniscus. I have one side pretty much cleaned up, but I'm guessing I had to file in maybe 5mm from the edge to get rid of it. Does this sound like what most of you see? Nothing to base this on, but I expected it to be a narrow and steep meniscus. I'll try to get a pic of the other side before cleanup.
Linear rails supposed to arrive from China this Friday...Last edited by wallyblackburn; 18-10-2017 at 06:57 PM.
19-10-2017 #6
I've not done epoxy before but your query may be answered in this excellent epoxy thread :
http://www.mycncuk.com/threads/8197-...-for-levelling
IIRC others have suggested pouring epoxy 40mm wide for 20mm rails to allow for a miniscus of about 5mm and then some.Last edited by AndyGuid; 19-10-2017 at 12:49 PM.
"Hacking" and "Modding"
Cnc router wood "roughing bits" anyone used these before?
By gavztheouch in forum Motor Drivers & ControllersReplies: 6Last Post: 27-04-2014, 10:11 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
BUILD LOG: Planning and build of my "8020" aluminium CNC Router
By monza in forum DIY Router Build LogsReplies: 14Last Post: 06-02-2010, 11:55 PM
