    My plan for the motors was, as you point out, cut some ventilation holes in the rails, and to try and mount a fan inside the rail (assuming the vibration isn't too much) - I'm not massively set on having them there, whilst its aesthetically pleasing I can see that placement causing all sorts of headaches while I'm trying to diagnose things!
    If motor heat is a concern (and generally they are designed to run hot without a problem, worth a quick check of the specs) you could always plumb them into the water-cooling loop you will have anyway for the spindle. Just a generic water block attached to the motors enough to pull away a good amount of heat - i've seen similar done for 3d printers where the motors are inside of the heated enclosure.
    Overall design looks very nice, you've clearly done a good deal of reading and research. I'm sure it'll be a good machine!
    End machining will be different re pulley or direct coupling. That is not to say you couldn't make a direct drive coupling end work with a pulley, you'll just be making your life more complicated.... go with best angular contact bearings you can afford.
    What a great idea! It was only this morning I was pondering making some sort of heatsink for them. Last night I read a thread on here from July which was quite negative about enclosed motors. I'd been thinking along the lines of aluminium block and some copper heat pipes, but water cooling is an excellent idea which deserves investigation :)
    http://www.mycncuk.com/threads/12075...ubing-X-Y-axis
    Thanks! As I say, mostly ideas are 'borrowed' from others ;) I'd love to make something that looks as professional as your current project (I love the way everything is covered and enclosed on yours) but I think that is a bit beyond me for now... maybe next time eh? :)
    Cool, thanks for the tip. I'm currently discussing Clive's suggestion with Fred, and taking his advice as he clearly knows his stuff. Hopefully not too far away from getting these major components ordered. Going to go with the upgraded bearings, and I'm also taking the opportunity to get the Spindle + VFD while I'm at it from someone reputable. Hopefully will also cut down on the shipping costs.
    Very exciting package just arrived!
    Still working my way through it, but all looks spot on so far. Very pleased and impressed by Fred.
    For those of you who are trying to price up your builds in the future, I think this set me back approx £1150. It includes everything you see above - all my rails, ballscrews (+bearings and mounts), and spindle, inclusive of delivery, VAT and Customs. I think it would have cost ~£2000 from a UK (re-)seller.
    Hi All,
    Hard at work as ever, just about finished welding the frame and will be painting soon... I've also got the main gantry structure together, and have starting cutting the aluminium components to form the Y and Z carriages. Photos soon, I promise!!
    Quick question though - my linear rails on the gantry are collecting a bit of dust - whats the best way to clean and (oil?) them? Any recommendations for grease to flush the HGR20 carriages through with? And I need a grease gun... any advice appreciated.
    Thanks in advance folks!
    I'd clean and flush with oil then use some multipurpose lithium 2 grease as its quite cheap to buy, some links on it below :).
    Spec me some lube!
    Profiled rails - Installation guidelines and manufacturer comparison chart
    Lithium Grease 400g - Toolstation
  6. The Following User Says Thank You to Lee Roberts For This Useful Post:
  7. #6
    Legend! Thankyou - Your forum searching foo is far superior to mine ;)
  8. #7
    Promised a couple of photos of the aluminium parts... so here we go - Don't judge my sloppyness too harshly ;)
    I've been using the printer at work to get drawings printed out as accurately as possible. I'm then using contact adhesive to attach them to the aluminium, which makes the drilling process a lot easier. The drawings get a little busy and unprofessional, but it helps when I'm checking how accurate the printout is to be able to quickly know what each relative dimension should be.
    Oh my life - the counter bore cutters are amazing. I love these things.
    So, after some bandsaw action, some broken drill bits, a screwed up aluminium part (try and spot whats asymmetrical!), and some other parts made, I finally got around to some rough first-time assembly this evening. The rails aren't perfect yet - they're dialed in to about 0.02mm from the surface of the Ali extrusion whilst I'm awaiting my precision straight edge which is back ordered, but the carriage went together like a dream, and runs nice and smoothly along them.
  2. BUILD LOG: Build Log: 4'x4' Moving Gantry CNC Router
    By GeorgeW21 in forum DIY Router Build Logs
    Last Post: 20-01-2019, 09:33 AM
  3. BUILD LOG: Ar last!!! Started my Gantry 3-Axis CNC Build
    By MikeyC38 in forum DIY Router Build Logs
    Last Post: 16-06-2018, 11:29 PM
  4. Any sugestions how to build my gantry
    By masinecc in forum Gantry/Router Machines & Building
    Last Post: 20-09-2015, 05:17 PM
