30-08-2019 #8
Understood. I've been scouring the forum and the web, but it seems my search-fu is a bit off, since I could not really find a conclusive answer on the differences of the UC300eth, UC400eth and AXBB-E, especially since CNCDrive's web pages are kind of scarce on the matter. As far as I am able to see, the 300 just has more IO than the 400, withe the AXBB-E has the same amount of IO as the 400, but a built in Breakout in a nicer package? Judging from this post, it seems that I can use all the IO that I can get, which would tip me in favour of the UC300eth.
Also, you mentioned being locked into Mach 3/4, as a negative. What other (better?) alternatives are there, and why is that?
I guess I just ignored the existence of 2020 Ballscrews :D I calculated it through in the motor spreadsheet, and, asuming I did all the correct modifications in terms of doubled motor RPM and doubled torque, I could actually now hit 12m/s rapids with the same motor, compared to 7.5m/s before. Thank you for the recommendation!
Building a PSU should be fine, for the most part, but just so I can make myself a complete picture, do you have any recommendations of AC Drivers that are worth it? I am kind of missing an equivalent to what mouser or arrow are in the electronics component space, where you have one page that you can search for all components you could ever need, all in one place. I never know where to look for the parts involved.
On a different note, I have seen Jog and MPG pendants mentioned and presented on shop pages. What do those things do exactly? What I have found repeatedly on the topic, is that they are used for manual operation of the machine, however I was under the impression that this would also be possible directly from the control software. Am I mistaken here, or is there a big advantage to using such pendants?Last edited by Chrono; 30-08-2019 at 07:42 PM.
BUILD LOG: Desktop build with zero budget. Critique my design please?
By Nealieboyee in forum DIY Router Build LogsReplies: 16Last Post: 25-07-2017, 03:50 PM -
NEW TO CNC - Starting design and so forth
By PSG in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 19-03-2014, 10:30 AM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
