01-09-2019 #15
Yes the same applies but I've yet to find a Closed-loop drive/motor combination that uses high inductance motors and just about every set I've used gives reasonable torque at higher speeds, most reach 1500rpm before torques drops away.
Also, there are closed-loop systems that use 3 phase motors which give much better torque and smooth operation. To be honest I mostly fit 3 phase systems on larger machines.
The only thing you have to watch for with smaller closed-loop systems is that they use low voltage, often 50Vdc drives and they do not tolerate more than 50V and will be damaged if rises above. This means you need to run safe margin, 44 - 45V is recommended. That said they still tend perform very well and better than a standard stepper at same voltage. Think this must be to do with the way the closed loop drives work.!
The bottom line that I've found is that closed-loop systems tend to be slightly stronger at higher feeds and the closed-loop drive ensure the position is maintained.
That said a correctly sized and set up Open-loop stepper system is just as accurate and shouldn't lose position if tuned correctly. Thou Closed-loop systems are coming down in price and the difference in price is now such that closed loop is the wiser choice.
BUILD LOG: Desktop build with zero budget. Critique my design please?
By Nealieboyee in forum DIY Router Build LogsReplies: 16Last Post: 25-07-2017, 03:50 PM -
NEW TO CNC - Starting design and so forth
By PSG in forum Gantry/Router Machines & BuildingReplies: 19Last Post: 19-03-2014, 10:30 AM -
Critique required on y-axis design.
By Spedley in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 06-05-2013, 09:17 PM -
About to build CNC miller, need design critique please
By JW149 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 23-04-2012, 09:28 PM -
NEW MEMBER: About to build CNC miller, need design critique please
By JW149 in forum New Member IntroductionsReplies: 1Last Post: 22-04-2012, 07:01 PM
