13-06-2020 #9
Ok your Stupid.
. . .But so am I because I'm not seeing it either.?
To me it's just homing each axis separately, waiting until both inputs go high and backing off until both go low then moving both to a set distance.! It's not doing any individual axis correction and as the switches don't move it's not corrected anything.? Yes, you can square the gantry by offsetting switches using this method, which is how mach3 etc do it but so can any homing system really.!
If you want a true squaring system then it needs to drive each motor separately and adjust to a set distance. For instance, the CSlabs squaring system gives you options to measure the offset between the switch triggers and gives you the option to apply a correction to a set distance or let the system do it automatically. In which case it drives both motors until the first switch goes high then backs both off until it goes low, then it drives the opposite motor until switch goes high measures the difference and moves that axis only the measured difference. It's strange to watch as it does a little dance and the gantry is then aligned to the first switch.
If you want to apply an extra offset to twist either side then you can set a +/- distance for either side which it will apply after homing. It then backs both off a set distance if required.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
