Thread: NordicCNC's build log
I wasn't referring to Delta when I said Chinese servo's it was a general point between Cheap and Expensive Servo's. Regards the Yaskawa motors -drive-cable package then can you post a link to where your buying because that's a very good price. What model is that.?
Regards the speed I don't see many that are rated at 6k rpm in the lower price ranges, 3K rpm is a typical rating with incremental encoders. Yes, they can be run up to 5-6K rpm but they are not rated to run at that speed constant.!
11-03-2020 #2
There are currently tons of offers on Ebay for SGM7J-04AF + SGD7S-2R8A00 at $450 new. I bought one like this a while back for a little less. I just asked for cables and they included them with no extra charges.
You can even buy the model with absolute encoder separately for less
(SGM7J-04A7 $160 + SGD7S-2R8A00 $260)
I didn't say 6000rpm is the nominal rating, but it's still useful for short rapid moves.
12-03-2020 #3
I'm surprised how much these have dropped in price, last time I looked, which must admit is quite some time ago, Yaskawa kits were like $900-$1100 range for 400W. I've never used them for this reason so I may look at these when a suitable job comes up.! . . . How easy or hard are they to setup/tune.? Do Yaskawa supply the Sigma tuning software for free.?
I'm surprised the absolute encoders are cheaper as well, not as many controllers about that can accept Absolute positioning so I would have expected them to be more. Thou absolute systems and Bus/Ethercat drives/controllers are coming down in price and more popular so maybe this is the reason.?
12-03-2020 #4
Yes of course software is free. I'm not yet to the point of tuning but having read the manual multiple times I don't expect many issues. You start with the auto-tuning and fine-tune from there.
IMO rotary absolute encoders are not worth the hassle. Their only use in a router/mill context is to spare you the homing after power-up. And obviously the controller must be able to interpret the special Yaskawa protocol and I think no hobby controller can at this point. It could be done with some knowledge with LinuxCNC+Mesa.
12-03-2020 #5
No, it's not obvious really, it's not uncommon for high-end Servo manufacturers to charge for specialist tuning software if not using their own controllers just like it's not uncommon for PLC providers to charge for programming software.
I'd be interested in hearing how you get on with tuning. What controller and which method of control +/-10v or Step/Dir .?
What hassle.? Far less wiring and setting up far as I can tell, esp if using Bus type.! . . . I've not used any yet but soon will be doing so I'll let you know.
13-03-2020 #6
Step/Dir is the most reliable and flexible. With analog +10V you're forced to control the servo in velocity mode.
With Step/Dir you can control it in position or velocity mode.
I'm also convinced position mode (letting the drive close all the loops internally) is the best way since the drive can do it much faster than the controller.
The interface of the servo drive is a whole other topic and has nothing to do with absolute encoders. For absolute encoders you need to connect a battery and 2 extra wires to request the position data when using the standard analog/pulse-train drives. And as I said above, the controller needs to be able to read the position data for the specific servo manufacturer.
Now if you use EtherCAT drives, indeed you just need a RJ-45 cable between the drive and controller (but still need the battery). But you have 2 more problems:
- you need to actually find one of those rare EtherCat drives. Yaskawa for example doesn't sell them in the Chinese market. So you would need to go through an official reseller and pay $$$, or buy another brand: Omron / Panasonic / Mitsubishi / Delta / Estun...
- be prepared to spend weeks and write some C to make the controller talk to the drive (LinuxCNC in this case, the only one supporting EtherCAT).
13-03-2020 #7
I agree about step/dir being simpler when drives handle position but not so sure that it's easier when your closing the loop back to the controller. Analog gives a little more control is my experience. But that said, my experience with servo's isn't massive and mostly with full closed-loop Analog controllers.
To be honest I think we are getting crossed wires a little here.! I know exactly what's involved with interfacing drives and wiring Absolute encoders etc.
My point was there's no more hassle using Absolute than incremental and there's actually less wiring required because you're not fitting home switches etc. Also if your using EtherCat or Bus type then there's even less wiring involved and less tuning involved because the controller and drives work closely together.
Also, I wasn't talking about Yaskawa Ethercat or trying to make Ethercat work with Linux or any other DIY controller. I'll be using an industrial Bus type controller with matched drives so i won't be needing to write any code etc.! . . . How long it takes to get up and running however will remain to be seen... .Lol
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
