Thread: NordicCNC's build log
11-03-2020 #9
The motors are 8Nm Lichuan closed loop steppers using 230Vac mains drives. It doesn't use a break because the gantry is vertical so Z-axis isn't fighting gravity, plus 8Nm is more than enough for this Z-axis even with heavy ATC spindle on it.
Regards the JMC then I've no experience using these motors or drives so I can't comment on how good or bad they are and I haven't looked at the specs, but if I'm honest I wouldn't use motors with integrated drives on a CNC machine. The heat and vibrations from the motors along with cutting debris, esp from aluminum coolant, etc, can't help with life expectancy but for me what's worse is the fact your running long signal wires back to the controller leaving you wide open to issues with interference from noise.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
