Andy,
Aluminium profile is very popular and based on the pictures we see on the forum is straight enough for directly mounting the rails. Problem is it costs an arm and a leg in Australia. My own machine has the rails mounted directly onto the steel section and relies on the straightness of the steel. It works OK for fully suported round rails but that may well not be good enough for Hi-Win or similar. The alignment of the rails to each other is done as pippin88 describes. Whether that's straight enough for you depends on what you want to make with it.
I'm not sure if anyone has tried a hybrid design with a steel frame and aluminium for supporting the rails. We're then into possible problems with differential expansion!
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Use of epoxy for levelling
By Neale in forum Gantry/Router Machines & BuildingReplies: 102Last Post: 25-08-2019, 04:21 PM -
Epoxy levelling, what's that magical spray ?!?
By aprex in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 09-12-2018, 05:14 AM -
is Epoxy levelling just for steel ?
By Hulksmash in forum General DiscussionReplies: 4Last Post: 20-07-2018, 07:42 AM -
By samsagaz in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 07-05-2016, 12:40 AM
