22-08-2021 #1
Hi, so today I tried to set the motor tuning in mach3. First setting the motors to as high a speed that they could take, then backing off. All good so far. Motors turn at a good rate, and sound ok. Then I try to set the steps and all hell starts to happen. First I set Mach3 up to run in mm. then I try to set the steps. First I input 10mm movement and the machine bed moves near the end stop and I need to stop the machine. I reduce the number of steps in the motor tuning page of Mach3 to 2000 steps from the 15600 it had input before. Then go back to set up the movement of the x axis. Input 20mm, the machine moves 37mm. Input 37mm set axis. Now the x axis moves at a crawl. What is going on. Thanks.
NEW MEMBER: You need a CNC to make a CNC.
By quadrilateral in forum New Member IntroductionsReplies: 4Last Post: 25-04-2017, 08:13 PM -
Make your own Super- PID ... not that hard to make ! .... says electronics genius!
By Buba b in forum General ElectronicsReplies: 4Last Post: 26-04-2013, 08:37 AM -
How would you make these, or something near enough...
By irving2008 in forum General DiscussionReplies: 8Last Post: 22-09-2012, 09:36 PM -
Using Games Contoller with Mach3
By cropwell in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 01-08-2012, 12:13 PM -
How to make something like this?
By lateAtNight in forum Machine DiscussionReplies: 2Last Post: 13-05-2009, 08:16 AM
