Thread: Need helpwiring up from scratch
12-07-2010 #17
Hi Irving
Are you the only techie on here?
Ok I'll peform some steps(bad pun) later on today as I need a rest from this.
I figure it just might be the bob as the charge pump led come and goes as does the power led,this board is basically naff because what happens is the led without pwer supply attached to 70v rail,glows dimly and when you attach the power supply its bright,I never known a piece of equipment that functions on the power side like that.
The charge pump led comes on and goes off when I reboot the computer ie it comes on just as it boots into the initialising screen and then goes out when windows is about to boot.
BUILD LOG: 1250 x 1250 cnc router (from scratch)
By Danielroyal25 in forum DIY Router Build LogsReplies: 56Last Post: 08-08-2014, 07:35 PM -
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
Starting from scratch, what would you use as a base for a CNC metal lathe?
By m_c in forum Lathes, Lathe Rebuilding & ConversionsReplies: 4Last Post: 23-01-2011, 05:37 PM -
Building from Scratch or follow some plans?
By Monk in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 12-08-2010, 10:27 PM
