    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Gents,
    I'm trying to build an L shaped box which has a z axis assembly mounted on it. Looking for someone who can CNC the following in MDF, plywood or alu (it's a prototype to try out an idea, so I'm trying to keep the costs down):
    The plates will need holes for screws / bolts and a few larger holes for bearings. MDF / plywood would need to be 15mm, alu would be 10mm thick.
    The above drawing is a rough estimate of how many plates are needed and the dimensions, I can of course provide more precise drawings for the job.
    Regards,
    dsc.
    Did you manage to get these cut?
    dsc's Avatar
    Hi D-man,
    nope, no offers yet. Would you be interested?
    Regards,
    dsc.
    Yeah I could be interested. However I don't get back until wed. If you like I can drop you a line then. In the meantime drop me a more accurate file over.
    All in mdf ok for you?
    dsc's Avatar
    Yup, all MDF is the plan. PM sent.
    Regards,
    dsc.
    dsc's Avatar
    Just a quick update of the overall view, going with 18mm MDF and cross dowels for assembly:
    Regards,
    dsc.
    dsc's Avatar
    Gents,
    this now needs cutting in 15mm Ecocast Alu:
    Any good souls willing to cutting this please PM. Material is Ecocast 15mm, which will probably needs supplying as I haven't got the means to transport 500mm x 1500mm 15mm thick plate.
    Regards,
    dsc.
  1. RFQ: Simple job cutting simple shapes out of camera lens cap
    By RockandGrohl in forum Projects, Jobs & Requests
    Last Post: 20-04-2013, 01:23 AM
  2. Break board 3-axis optical isolation, simple!
    By thjremy in forum Electronic Project Building
    Last Post: 06-04-2013, 04:42 PM
  3. stability - monolith vs. two-part assembly
    By dsc in forum Gantry/Router Machines & Building
    Last Post: 24-10-2012, 03:03 PM
  4. Z axis assembly - unsupported rail for very limited movement
    Last Post: 10-10-2012, 12:44 PM
