27-03-2013 #1Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
28-03-2013 #2
Shearing would probably be the cleanest method but it depends how complex the piece is. Another off-the-cuff option is a CNC nibbler. Never seen one, but I'm sure they must exist.
28-03-2013 #3
In 1 to 2mm stainless a laser will give a very clean edge, yes I know they are expensive but you sub con the job out and pay by the cut inch [ or mm ]
John S -
28-03-2013 #4
Here you go, one of these would probably do the job.
EUROMAC CNC PUNCHING MACHINES - YouTube
28-03-2013 #5
28-03-2013 #6
RFQ: Water or laser cut stainless flanges
By r0bsk1 in forum Projects, Jobs & RequestsReplies: 2Last Post: 23-09-2013, 08:12 PM -
RFQ: RFQ: Micro Precision in Stainless Steel.
By mikewatch in forum Projects, Jobs & RequestsReplies: 3Last Post: 12-04-2013, 11:49 PM -
RFQ: 16mm long stainless pins with m5 tap
By dazza in forum Projects, Jobs & RequestsReplies: 12Last Post: 11-03-2013, 03:12 PM -
stainless steel fasteners - quality
By dsc in forum Metalwork DiscussionReplies: 7Last Post: 30-11-2012, 12:35 PM -
Mini lathes - possible to turn stainless?
By HankMcSpank in forum Lathes, Lathe Rebuilding & ConversionsReplies: 27Last Post: 03-08-2010, 03:14 AM
