No he won't need to over spec the PSU those motors will easily handle 50V so running at 44-45Vdc on 50V drives will be fine for most small to medium machines or winder, so they will migrate nicely when the time comes and he will be getting optimum performance from the drives/motors at all times.
24V on the other hand while perfectly fine for a winder will be very restrictive in speed terms for a CNC machine. TB based 3 axis boards will probably run fine without issues at 24V but they don't like staying alive much after 36V.
The motors are capable of running above 50V so why not have the ability to use there full potential, Better to have spare capacity than be lacking at later date when needed.
09-09-2013 #2
09-09-2013 #3
Only in terms of amps but he'll only pull what's needed there.!! . . . . But yes your correct I am assuming he's thinking to use same motors where he might not.!!. . . But still he possibly could want to use the same drives and if he had 50V drives with 44V 8-10A psu then he easily could do it where has with poxy TB based drives then it start again from scratch.!!
Anyway only he knows where he wants to go we just point out the different directions he can take.!!Last edited by JAZZCNC; 09-09-2013 at 12:30 AM.
10-09-2013 #4
The cnc build at a later date will be with new motors, drives etc. Thanks for the responses they have really helped, especially when it comes to power supply choice. Once I have it up and running I will post some pictures.
10-09-2013 #5
Going into competition with Bareknuckle
10-09-2013 #6
11-09-2013 #7
I've made a CNC guitar pickup winder previously...& I agree....make it as cheap as chips - the TB based boards are awful, but that's mainly when they are pushed....and winding 0.06mm dia. copper wire onto a bobbin, is not going to stress anything.
Two of these ought to be fine for a CNC guitar winder (overkill, but they're the cheapest option)...
CNC Router TB6560 Single 3.5A 1 Axis Stepper Stepping Motor Driver Board Control | eBayLast edited by HankMcSpank; 11-09-2013 at 10:14 AM.
11-09-2013 #8
I have a TB6560 3 axis board and 3 Nema 23 steppers as well as a 24V PSU (http://www.mycncuk.com/forums/router...rs-planes.html)you can have (well buy!!) as a package...bought these before coming on the forum and they'd be useless for my build...PM me if you're interested and I'm sure we could come to some arrangement...
11-09-2013 #9
What software did you use to run the cnc winder?
ebay power supply
By irving2008 in forum General ElectronicsReplies: 91Last Post: 29-04-2012, 06:28 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply problms
By Scott in forum General ElectronicsReplies: 13Last Post: 11-07-2010, 12:58 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
