    Quote Originally Posted by ~andy View Post
    He isn't going to run a 3/4 axis router with 2 x 1.68a steppers, so the PSU would have to be larger than needed
    Only in terms of amps but he'll only pull what's needed there.!! . . . . But yes your correct I am assuming he's thinking to use same motors where he might not.!!. . . But still he possibly could want to use the same drives and if he had 50V drives with 44V 8-10A psu then he easily could do it where has with poxy TB based drives then it start again from scratch.!!
    Anyway only he knows where he wants to go we just point out the different directions he can take.!!
    The cnc build at a later date will be with new motors, drives etc. Thanks for the responses they have really helped, especially when it comes to power supply choice. Once I have it up and running I will post some pictures.
    Going into competition with Bareknuckle
    Quote Originally Posted by timellis View Post
    In which case then Andy is absolutely correct just throw 24v at it cheap has possible and the 3 axis TB based boards will probably be the cheapest route. @ 24v they will be ok, go much higher and they like letting out magic smoke.!
    I've made a CNC guitar pickup winder previously...& I agree....make it as cheap as chips - the TB based boards are awful, but that's mainly when they are pushed....and winding 0.06mm dia. copper wire onto a bobbin, is not going to stress anything.
    Two of these ought to be fine for a CNC guitar winder (overkill, but they're the cheapest option)...
    CNC Router TB6560 Single 3.5A 1 Axis Stepper Stepping Motor Driver Board Control | eBay
    I have a TB6560 3 axis board and 3 Nema 23 steppers as well as a 24V PSU (http://www.mycncuk.com/forums/router...rs-planes.html)you can have (well buy!!) as a package...bought these before coming on the forum and they'd be useless for my build...PM me if you're interested and I'm sure we could come to some arrangement...
    Neil...
    Build log...here
    What software did you use to run the cnc winder?
    a free program called gcoil ...which you enter a few parameters of your bobbin & it produces g-code for your particular wind.
    You then load the g-code into your CNC app.
  1. ebay power supply
    By irving2008 in forum General Electronics
    Last Post: 29-04-2012, 06:28 PM
  2. Replies: 0
  3. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
  4. power supply problms
    By Scott in forum General Electronics
    Last Post: 11-07-2010, 12:58 PM
  5. power supply
    By hitmythumb in forum General Electronics
    Last Post: 21-06-2009, 10:27 AM
