    any suggestions to what sort of filters to use, i guess it will need to be fairly large to prevent the chances of it geting blocked up to quickly? how about the vfd? originally i had it mounted to the gantry but then realised it was probably better some were else. Is it something i need access to the hole time so needs to be some were accessible and if so then how would i protect that from dust all so? put it in a separate box?
    cheers
    Big Steel box with 2 fans pulling air in thru good paper filters and one pulling it out. Filters like this. http://www.apc.com/products/family/?id=414
    Car air filters also make good filters but you'll need to make an housing similair to whats in the picture. Which is easy made from thin ali sheet if you have a working machine and a good little test.
    cheers thanks i will see what i can find at a local car spares shop, should i put the vfd in with it all or separate do you think?
    Quote Originally Posted by charlieuk View Post
    Put it inside with it. If you need or want to see the display then depending on VFD make you can often remove the front display and put externally.
    If your controling thru software then you don't really need access but it's nice to be able to see the display and have it set for Amps. This will give an indication to cutter wear and spindle load. (thou don't think your foam will challenge the spindle any.!!)
    cool many thanks will work on that principle.
    like this;
    http://www.mycncuk.com/threads/6565-...6651#post56651
    make sure the fans blow into the panel (via the filter), not suck out of it, this is to keep the air pressure inside the panel higher than outside.
  1. RFQ: Does anyone want to build me a cnc router?
    By totally useless in forum Projects, Jobs & Requests
    Last Post: 08-05-2014, 09:55 PM
  2. Does anyone want to build me a cnc router?
  3. How Not To Build A Router
    By Clive S in forum Gantry/Router Machines & Building
    Last Post: 17-11-2013, 10:09 AM
  4. BUILD LOG: CNC Router New Build
  5. BUILD LOG: A3 Router Build
