Thread: VFD error
19-05-2014 #5
Does your spindle have the GX16-3 connector ? Have a look at the PLUG as well and see if there are any burn marks on the female pins they are split as well. I t could be the cable from the VFD has a break somewhere and that has shorted back to the spindle.
E14 "The inverter is protected by the detection ofground faults between the inverter output and themotor during powerup tests. This feature protectsthe inverter, and does not protect humans."
Sounds likely that there is a break in the cable which has flashed at the GX16 connection causing the split in the pin to draw together.
repeating code error
By motoxy in forum Programmers CornerReplies: 2Last Post: 28-02-2014, 07:51 AM -
VFD problems, please help. error code DL
By humbo3d in forum Spindles & Drive MotorsReplies: 2Last Post: 09-02-2014, 08:10 PM -
huanyang vfd 2.2 error E.CO.A
By edgas10 in forum General ElectronicsReplies: 0Last Post: 01-07-2012, 08:12 PM -
Solidcam error
By Kai in forum SolidworksReplies: 5Last Post: 10-05-2011, 03:41 PM -
Error on a Bosch cc 220 control (Need help)
By Andre in forum General ElectronicsReplies: 2Last Post: 01-10-2010, 07:33 AM
