  1. #24
    Quote Originally Posted by PAULRO View Post
    RELAY 1 is on . i metered accross the N.O contact and common and have continuity.
    Ok well first makes sure Spindle is OFF. Type M5 in MDI. Check Continuity again.
    If still got continiuty then Change active state (NO Tick) and Check continuity again. It should drop Off. Type M3 and it should give continiuty again.
    If it does you are working correctly.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
