Thread: Let the fun begin !!! ???
26-05-2015 #22
Ok great.!! . . . Now we can turn to speed control. But we are not going to connect any wires yet and stay with the meter.
First make sure Spindle output is enabled in Motor outputs and setup correctly. It should be set to:
Step pin = pin14
Step Port =1
Step Low active = No tick.
Next Spindle Setup. Go to Spindle control and select:
Use Spindle motor output = Ticked
PWM Control =Ticked
PWMbase Freq = 50%
MinimumPWM = 5%
Next go to menu Config/ Spindle pulleys:
Pulley #1
Minimum Speed = 0
Maximum Speed = 24000
Ratio = 1
Now set meter to DC volts. Put Positive Probe to FIV and Negative Probe to GND on XP24. ( You will need 10V from VFD connected to 10V on XP24 but leave ACM & VI disconnected)
With Spindle off (M5) you should have 0v on meter. Check this first before doing any thing.
If Ok and 0V then type M3 S12000 in MDI and you should read a voltage around 5v try this and let me know.!Last edited by JAZZCNC; 26-05-2015 at 10:26 PM.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
