19-06-2014 #5
If you are using ali extrusion for your frame then you may be able to get some ideas from my build here: http://www.mycncuk.com/threads/5139-It-s-begun
Some caveats though - my machine is compromised by using the round supported rails. Its not useless by any means, but not as good as using profiled guides/rails and bearings (especially on the Z and Y axis). I think your rails should also be mounted differently (especially X axis).
Most guys on here also go for a welded steel frame, as it is cheaper, generally stronger, but of course you may not have someone who can weld it for you (I also did not at the time).
Oh also consider using twin X axis ballscrews (one on each side).
I'm sure you get tons of advice and best of luck with the build.Last edited by Washout; 19-06-2014 at 09:21 AM.
NEW MEMBER: where to buy aluminum extrusion
By troyboy1 in forum New Member IntroductionsReplies: 3Last Post: 21-07-2014, 01:52 PM -
Stepper controller to manually input a specific degree
By Web Goblin in forum Motor Drivers & ControllersReplies: 11Last Post: 13-10-2013, 05:47 AM -
tool for aluminum on uk
By edgas10 in forum Tool & Tooling TechnologyReplies: 1Last Post: 26-04-2011, 11:23 AM -
Milling aluminum and cooling
By Tonny in forum Swarf & Chip ManagementReplies: 6Last Post: 12-07-2010, 03:48 AM
