I don't use Vcarve pro but this is easy to do in any Cad/Cam package and I do it all the time for parts that don't need high accurecy. It's just a matter of scale and if you have templates to reference from then it's no problem.
Easy way is to draw 2 lines the length and width of the part then scale the photo to these lines. This will get you to within nats bollock in size then just use the trace function or as is often the case it's just as quick to free hand trace around the picture. Then create G-code and cut air around your original template to see how it matches. Make any changes as needed.!!. . . . . Simplizzzz.!Last edited by JAZZCNC; 21-08-2014 at 11:40 PM.
vcarve pro 7
By GeoDurie in forum CAD & CAM SoftwareReplies: 3Last Post: 22-05-2014, 02:46 PM -
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
RFQ: MDF Panels (+ More)
By codytom in forum Projects, Jobs & RequestsReplies: 6Last Post: 09-04-2013, 09:16 PM -
Vcarve to Mach3
By jcb121 in forum VectricReplies: 6Last Post: 01-04-2012, 05:21 PM
