    You can import a jpg file into most cad programs as a reference image and then on a different layer trace round the outline of the panel with lines, arcs etc. If you measure one straight edge of the template you can then scale your drawing after you've drawn it. I use this for converting old RC plane plans to CAD drawings...scan them in, trace round the lines, scale and then you're done...simples
    Neil...
    Build log...here
    @calibanman, how did it finally work out for you ?
    Hi EddyCurrent
    I'd like to thank everybody for their contribution to my problem. I've drawn round the shapes in VCarve, turned the CNC machine into a plotter and made my adjustments with the node editing, then cut them out. Up to now everything seems OK.
    So thanks again. But I warn you, I will most probably be back with a new set of problems in the near future.
  1. vcarve pro 7
    By GeoDurie in forum CAD & CAM Software
    Last Post: 22-05-2014, 02:46 PM
  2. RFQ: Gantry side panels
    By fvfdrums in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 03:50 PM
  3. RFQ: Panels cut from soft plywood
    By Rockeyes in forum Projects, Jobs & Requests
    Last Post: 12-04-2013, 04:38 AM
  4. RFQ: MDF Panels (+ More)
    By codytom in forum Projects, Jobs & Requests
    Last Post: 09-04-2013, 09:16 PM
  5. Vcarve to Mach3
    By jcb121 in forum Vectric
    Last Post: 01-04-2012, 05:21 PM
