Thread: Z-Axis setup
    Quote Originally Posted by Yaser View Post
    [/B]By the way, the Y-Axis and Z-Axis will act as a single unit.
    Think you better explain this one because you got me head scratching.?
    Z axis design wants to be strong and uncomplicated. Short as possible with good bearing spacing. Widest foot print as possible on the rear plate where it meets the connecting axis which in your case I've no clue what your meaning. . Lol
    Don't use thin flimsy plates.
    For ease of building and setup then you don't need a bottom bearing on the ballscrew if screw not too long.(upto 350mm) Optional if you connect motor to screw with a timing belt but doing so is better for resonance reasons and gives option of a ratio if required.
    Usually stronger if rails are placed on the front plate, thou dependant on travel amount not always the case.
    Draw it up and let us take a look. Pics of what you have so far will help also.
    Hi Jazz,
    Thanks a lot for your input/advice. As I mentioned I am new to CNC building so please pardon me if the questions I ask seem trival.
    Can u please elaborate the following:
    1) Widest Foot print possible?
    2) What would be considered to be thin flimsy plates?
    I will try to have some pictures and perhaps u can comment on what can be adjusted.
    Thank you very much
  1. Setup for squaring twin X-axis gantry
    By routercnc in forum Gantry/Router Machines & Building
    Last Post: 26-03-2014, 11:13 PM
  2. 2 motors on X how do I setup Mach3
    By phill05 in forum Artsoft Mach (3 & 4)
    Last Post: 04-02-2013, 09:33 PM
  3. FOR SALE: 4th axis setup
    By johngoodrich in forum Items For Sale
    Last Post: 13-06-2012, 06:17 PM
  4. CNC Machine Setup Blog
    By marchantdice in forum General Discussion
    Last Post: 17-10-2011, 08:31 PM
  5. Motor & Driver setup
    By action-kat in forum General Electronics
    Last Post: 19-07-2010, 11:24 AM
