    Howdy,
    I use an early version 1 of Mach cnc. I mostly mill complex low relief forms in polystyrene using Aspire to write the gcode. I have started recently to use the profile cut mode in Aspire. It has highlighted an issue which I need to address.
    In profile mode, infact all modes the program has a tendency to not cut into corners preferring the shortest distance. I therefor must need to instruct Mach and or Aspire to slow/ recognise certain angles.
    My question is how do I do this? Do I need a different version of Mach 3, and which page allows me to make the alterations to stop it cutting corners.
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Are you using bits that are a greater dia than corners you are cutting? ..Clive
    Hi Clive,
    Thanks for reply. The bits are less dia than the corner radius.
    Quote Originally Posted by marbles View Post
    Hi Clive,
    You might be better posting some Gcode Have a read through this http://www.cnczone.com/forums/mach-m...are-posts.html ..Clive
    i think the issue I have is related to Constant Velocity versus Absolute Stop on the Config page of Mach.
    I think there is a setting for this in Mach on the settings page. Clive
  1. the mystery of the wonky corners
    By kingcreaky in forum Machine Discussion
    Last Post: 06-05-2014, 03:58 PM
  2. pulley center distance vs. belt tension
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 13-01-2014, 10:48 PM
  3. RFQ: Mdf Cuts for CNC frame.
    By mZeles in forum Projects, Jobs & Requests
    Last Post: 12-03-2013, 04:41 PM
  4. Adding a 'Park Mode' to a cnc router?
    By routercnc in forum Computer Software
    Last Post: 18-06-2010, 06:10 PM
