10-01-2017 #19
for info i have nema 24 4nm steppers from cnc4u,
This is my first router it will be used for multicut materials (aluminium, wood, polycarbonate, etc...) and i'm looking for the best resolution before speed, but on the other end i understand that for some materials.. a fast feedrate could be need, so maybe an rm2010 could be an intermediate solution...
1 - we always see Z axis with rm1605, i assume with 1:1 or another ratio ?
2 - For my long axis to get a 1400mm travel i could use a 1550mm rm2010 with an 1:1 ratio but will it work correctly ? (whipping...)
if it wont work wich length would you use maximum ?
3 - If using RM2020 for cutting aluminium do you think i can have a good resolution with a pulley change to something like 4:1
Many thanks for your help..
WANTED: 150mm dia x 15mm wall Ali pipe
By r0bsk1 in forum Items WantedReplies: 9Last Post: 12-06-2014, 04:19 PM -
Melbourne Andy CNC 1220x810 working area
By AndyGuid in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 17-04-2014, 11:41 AM -
WANTED: Profile rails, 600mm and 900mm
By Jonathan in forum Items WantedReplies: 2Last Post: 16-08-2011, 09:18 AM -
Stick with Ali profile or venture into plate?
By ecat in forum Metalwork DiscussionReplies: 14Last Post: 22-08-2010, 09:00 PM -
BUILD LOG: Newbie First Build 3000mm x 1500mm
By psiron in forum DIY Router Build LogsReplies: 16Last Post: 16-07-2010, 11:02 AM
