30-01-2016 #191
Got it. Thanks Jazz.
X and Y are cool. For me now it's just the Z that changes after each tool change.
Have you got an automatic tool change system - Is that another ball game ?
Where would i start with that ?
I am (EDIT:: reasonably) pleased with this, but it took me a whole week to design and make. Hence the 1/2 million lines of gcode and 9 Hrs + machining.
Onto the next idea...
Do you think i could make these out of moulds using the CNC to make a plug?
MartinLast edited by mturneruk; 30-01-2016 at 08:18 PM.
30-01-2016 #192
You start by taking out a Mortage and or selling the Wife. Then yes it's all new ball game. Not massively difficult but expensive and will require some coding or Macro writing. This is one of the reasons why UCCNC is restrictive because you can't easily take full control for things like ATC.
Looks very nice but 9hrs is nothing for 3D work. I've got people who makes things that take 12-18hrs minimum with Millions lines of code and are only 200x100 rectangles. I cut 6ft sq mural made in 4 pieces for school wall that each piece took 22hrs and ran continous.
As you get more experienced you'll be surprsied how much you can fetch Cycle times down. If your doing 3D jobs it's worth Re-tuning your motors biased towards acceleration rather than velocity. It will bring cycle times down considerably.
30-01-2016 #193
I was increasing my acceleration and velocity as I went along. Bit at a time.
What i noticed was that the Z axis was the limiting factor, so i increased it, and then obviously my job completed faster, but I felt sorry for my machine. Everything was very warm. Spindle, steppers etc.
Not boiling though, but very warm.
Also I only have one 3mm ball nose bit and i didn't want to break it. I roughed with a 6mm ball 2.5mm stepover, 5mm DOC and then finished with a 3mm ball with a step over of 0.75mm.
Forgetting the design I did, what is the optimum tool size / Stepover for this kind of thing?
Something tells me it's better to design something that allows you to use a bigger tool.Last edited by mturneruk; 30-01-2016 at 08:38 PM.
30-01-2016 #194
One other thing was that the amount of clean up I had to do was a significant pain in the ass. I wondered if running the spindle faster or slower might reduce that. I tried a range of speeds, but settled on about 15000 as it sounded nice.
30-01-2016 #195
PS. Can't sell the wife, she looks after the kids while i'm CNC'ing.
04-03-2016 #196
check out www.diycnc.co.uk
spindle v5 might be your answer
02-08-2016 #197
I would like to thank mturneruk, Jazz and eceryone else for the amount of information contained within this entry.
I am at the same position as mturnerUK and just building my control panel and using Jazz's wiring diagram.
Will post images as the build goes on (own thread) but the information has been priceless ;-)
Thanks,
Ian
13-08-2017 #198
Hi Guys
I wish i had found this thread, before i started buying bits for my Isel 2018 conversion, I have spent a few hundred this week and after reading this for first time im regretting 90% of it, I have working steppers on machine and today removed them to replace for ones with wiring colours i can make parallel, I have 8 wire ones now but dont know enough to guess at where wires go
Steve
13-08-2017 #199
13-08-2017 #200
hi thank you for reply,
here is what im doing http://www.mycncuk.com/threads/11184...18-or-Educam20
here is a link to the only data sheet i can find data sheet, Sorry Lee
http://www.cnczone.com/forums/attach...6/83328.attachLast edited by Steve-m; 13-08-2017 at 10:59 PM. Reason: added info
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
1.5Kw Chinese Spindle help
By Hasanain in forum Generic Chinese SpindlesReplies: 3Last Post: 26-05-2016, 10:38 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
WANTED: Spindle holder for 1.5kw Chinese spindle.
By jcb121 in forum Items WantedReplies: 19Last Post: 14-10-2011, 02:07 PM
