Thread: Aluminium profile cnc build
21-07-2016 #21
21-07-2016 #22
21-07-2016 #23
The one in my drawing is 20.6 mm and it is exactly the same like in any drawing you could find on internet with nema 23 dimdnsions. Double standard?
Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
21-07-2016 #24
Is your measurement just to the end of the key in the shaft?
http://cnc4you.co.uk/resources/Stepp...1B%203.1Nm.pdfLast edited by Clive S; 21-07-2016 at 11:10 PM.
22-07-2016 #25
My motor shafts don't go all the way through the pulley and have been running fine for years.
If it is more than half way into the pulley and the grub screws have a good lock onto the shaft I don't see any major problems.
22-07-2016 #26
Just looked at my Z axis and it looks a little like this.....
Shaft is 3/4 the way in the pulley and held on with 2 off M3 grub screws @ 90° to each other...
Plate thickness is 3mm so 17mm pocket machined out the plate.Last edited by njhussey; 22-07-2016 at 12:23 PM.
22-07-2016 #27
So do we actually need that thickness of a plate if anyway we are machining almost all the through the thickness?
22-07-2016 #28
It has to have some inherent stiffness to stop any bending forces from the belt, I had it 20mm thick as it came out the same sheet as the rest and I needed the thickness to put the M8 bolts into....
22-07-2016 #29
So in my case i have it 10mm and attaching it to the other plate with M6 screws. Is that allright?
25-07-2016 #30
Is there any chance that somehow i have blocked my posts, so others cant see it? The same with massages? Or people just doesnt respond as much as i would like? :D
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
