Thread: Aluminium profile cnc build
Did someone bought linear parts from aliexpres sellers the jason august store, huijuan mei or transmission cnc? They are quoting a bit cheper..
Išsiųsta naudojantis SM-G900F Tapatalk 4 Lt
20-10-2016 #2
Hi Valdis
You must have got the same email as i did this morning, @ least the seller is quoting genuine Hiwin. A lot of the sellers will show Hiwin in there add but if you check the description it says picture is just for general information and the supplied item will prevail so chances are they won't be Hiwin.
Regards
Mike
31-10-2016 #3
Which spindle bracket is better? Thinking if they will have the same strenght?
This one:
http://www.ebay.co.uk/itm/Dia-80mm-S...3D322225414288
or this one
http://www.ebay.co.uk/itm/80mm-Diame...3D322225414288
31-10-2016 #4
Should be the same I think.
01-11-2016 #5
01-11-2016 #6
Definitely the second one, but beware, even that can crack.
http://adapting-camera.blogspot.se/2016/09/cnc-upgrade-progress-disaster-strikes.html
This is how I fixed it:
http://adapting-camera.blogspot.se/2...g-cracked.html
Anyway, I bought a new one but have not installed it yet and I think the quality is the same. Cast aluminum, at least the way these cheap brackets are made, are not the best for this purpose.Last edited by A_Camera; 01-11-2016 at 12:45 PM.
01-11-2016 #7
I'd buy a SBR50UU and use the housing as it's 80mm and slit along one side to clamp the spindle....
01-11-2016 #8
Thanks guys, placed an order for second option. We will see how it will hold.
Today got my spindle and was surprised to find 3pin plug for it. Isnt it supposed to be 4pins ( three phases and earth)?
Another thing the locking nut has been drilled, is that they way they tried to balance it? Is it normal?
Išsiųsta naudojantis SM-G900F Tapatalk 4 LtLast edited by valdis034; 01-11-2016 at 08:57 PM.
01-11-2016 #9
exactly the same as mine.
yes the drill holes are their attempt at balancing the lock nut.
Mine only has three pins - i connected the earth ground to the shell of the plug and tested for connectivity to the body, the whole machine is earthed anyway and the motor has a metal body so should be safe enough.
01-11-2016 #10
Off course with spindle got the inverter and have the electrical box, thinking that box might be a bit small for all the stuff..
what size enclosures you have to fit everything?
Here will be 4 drivers, BOB, toroidal transformer, 24v supply, realays, filtered fan on the door or on the side of the box and some wires..
Aluminium Profile - ValuFrame?
By Tenson in forum Marketplace DiscussionReplies: 12Last Post: 24-09-2020, 07:21 PM -
Aluminium Profile
By amxen in forum Metalwork DiscussionReplies: 2Last Post: 13-08-2015, 07:37 PM -
eBay: KB Aluminium Profile Supplies
By KB Aluminium in forum Items On eBay UKReplies: 45Last Post: 20-05-2015, 03:46 PM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
Tapping Aluminium profile
By jonbabbz in forum Tool & Tooling TechnologyReplies: 3Last Post: 28-05-2012, 08:09 AM
