04-01-2017 #1
The tracks you have for the DC positive are wide enough for maybe 3 amps ... certainly nowhere near 14A. The current wont be near to 14A, but still those tracks are optimistically sized.
You could do something similar to mine - happy to share the dxf for the PCB.
04-01-2017 #2
04-01-2017 #3
Email: [email protected]
Web site: www.jazzcnc.co.uk
04-01-2017 #4
10 amps through a similarly sized track:
Attachment 20223
Attachment 20225
Attachment 20224
So don't forget the volt dropped across the PCB track
Sorry, I was bored...
04-01-2017 #5
Jonathan this pcb is for 3x3A steppers which takes no more than 7A from my calculation, but real test by clamp meter revealed that was no more than 0.86A therefore even perforated prototype board worked fine (but should not)
I really should't show that - 1st pcb cut (on the left was Eagle pcb, on the right my revised version which still is not wide enough)
For my 70VDC 7A motors I use the same layout but wider path on pcb.
Just checked current-carring capacity and 1mm2 will handle 11A.
For 16.5A i need exactly 1.5mm2 conductor, so 1mm pcb has 0.035mm of copper.
Path width=1.5/0.035=42.86mm - my entire PCB is 50mm wide, according to this calculation we both wrong
I like that drain resistor - how many ohms?
Where do you buy components if you don't mind me to ask - your price are better than mine:(
04-01-2017 #6
04-01-2017 #7
05-01-2017 #8
05-01-2017 #9
Hi guys,
After receiving a couple of reports on the original thread (it needing attention), I decided to split the discussion, allowing it to continue regarding the selection process, with a new discussion for the PCB side of things, as both topics deserve the proper observations.
You can find the links to each discussion below, thank you to everyone involved, feel free to continue both discussions:
Link 1: Help please with toroidal transformers selection
Link 2: Please don-t push 14A through that PCB !!!
.Last edited by Lee Roberts; 05-01-2017 at 04:50 PM.
.Me
The Following 2 Users Say Thank You to Lee Roberts For This Useful Post:
FREE: Green/Red/Black 3P push button rocker switches
By Lee Roberts in forum Classified Ads, Buy, Sell & SwapReplies: 3Last Post: 08-05-2016, 07:38 AM -
push down plate,
By jcb121 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 31-07-2013, 11:38 PM
