Supplied size accuracy on tooling plate.....
		I'm looking to buy some pieces of tooling plate from Clickmetal.co.uk to start making my CNC router. As my machining capabilities are somewhat limited until the project's finished, my intention is to buy them slightly oversized and trim to fit - just wondering how accurate their cutting tends to be please?
		Re: Supplied size accuracy on tooling plate.....
		Have you tried asking them what their cutting tolerances are?
		Well, on their site they state +/-2mm IIRC - which is a lot, but then these days as a retailer, covering your arse is very important ;-) - I was just wondering what they actually tended to achieve.
Voicecoil
 I buy from them a fair bit, all within less than 1mm.
		Cheers, many thanks for the info :beer:
Voicecoil
 I dont know the exact measurements as Ive never really been too concerned. I tend to order oversize and then machine down. If you are working out of if you can build something from their cut sizes, probably could but probably nothing that needs ultra precision.
		I too will be ordering slightly oversize and trimming down - but I wanted to minimise the amount of trimming needed, as I'm going to have to call in a favour from a friend to do it. And in the past I've had some pretty randomly sized bits of metal from other vendors.
Voicecoil
 You wont have that problem here .....
If you order 102mm to get down to 100mm, it will be around 102mm.
