    I'm looking to buy some pieces of tooling plate from Clickmetal.co.uk to start making my CNC router. As my machining capabilities are somewhat limited until the project's finished, my intention is to buy them slightly oversized and trim to fit - just wondering how accurate their cutting tends to be please?
    Have you tried asking them what their cutting tolerances are?
    Well, on their site they state +/-2mm IIRC - which is a lot, but then these days as a retailer, covering your arse is very important ;-) - I was just wondering what they actually tended to achieve.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Week Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    I buy from them a fair bit, all within less than 1mm.
    Cheers, many thanks for the info
    Chaz's Avatar
    I dont know the exact measurements as Ive never really been too concerned. I tend to order oversize and then machine down. If you are working out of if you can build something from their cut sizes, probably could but probably nothing that needs ultra precision.
    I too will be ordering slightly oversize and trimming down - but I wanted to minimise the amount of trimming needed, as I'm going to have to call in a favour from a friend to do it. And in the past I've had some pretty randomly sized bits of metal from other vendors.
    Chaz's Avatar
    You wont have that problem here .....
    If you order 102mm to get down to 100mm, it will be around 102mm.
  1. Alloy 5083 Tooling plate Suitable for gantry build?
    By PaisleyPCdoctor in forum Gantry/Router Machines & Building
    Last Post: 20-01-2018, 07:05 PM
  2. VFD supplied by RCBO vs MCB?
    By mattnedgus in forum General Electronics
    Last Post: 08-07-2016, 12:47 PM
  3. Bad accuracy with my cnc machine
    By masinecc in forum Gantry/Router Machines & Building
    Last Post: 23-04-2015, 06:59 PM
  4. Aspire tutorials supplied with the installation dvd
    By habibuzziwa in forum CAD & CAM Software
    Last Post: 17-11-2012, 03:38 PM
  5. Stepper shaft size and pulley bore size problem
