Re: Converion based upon my old Deckel Mill
This forum entry refers to the problem and sugests a solution.
https://cambamcnc.com/forum/index.ph...sg6459#msg6459
To change the post-processor click on the 'system' tab, and select the correct post-processor from the list in there. If this doesn't work then try a search on the CamBam forum. Copy and paste the error message into the search box. There are plenty of results to choose from!
John11668
So when I click start , the process begins and looks promising until it stops and I get I get an error message .
Says "Radius to end of arc differs from Radius to start (with block reference )
Block is G2 F800.0 X180.0 Z-0.0856 I-12.5717 J58.6681
No radius in there to trouble us , is there ????
Go into mach3 general config and change the I/J settings that should get rid of the message.
Kitwn
Been to the forum and this does seem to be a common problem, but there are hundreds of similar blocks in the code so editing isnt going to be the answer.
Have tried changing the PP to Mach 3 but the indicator ( green arrow )stays at default . Does this only work on licensed version perhaps ?
Will look at that Jazz but immediate question is What do I change them to? Remember I am a raw newbie :witless:
Got it !
Config/ general config/ then change IJ mode from absolute to incremental and that seems to have done the trick
Starting to make some progress now . (I hope )
Thanks Guys.
John11668
Got it !
Thanks Guys.
Yep, that's the one.
