01-06-2020 #21
This forum entry refers to the problem and sugests a solution.
https://cambamcnc.com/forum/index.ph...sg6459#msg6459
To change the post-processor click on the 'system' tab, and select the correct post-processor from the list in there. If this doesn't work then try a search on the CamBam forum. Copy and paste the error message into the search box. There are plenty of results to choose from!An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
01-06-2020 #22-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
01-06-2020 #23
Been to the forum and this does seem to be a common problem, but there are hundreds of similar blocks in the code so editing isnt going to be the answer.
Have tried changing the PP to Mach 3 but the indicator ( green arrow )stays at default . Does this only work on licensed version perhaps ?
01-06-2020 #24
01-06-2020 #25
Got it !
Config/ general config/ then change IJ mode from absolute to incremental and that seems to have done the trick
Starting to make some progress now . (I hope )
Thanks Guys.
01-06-2020 #26-use common sense, if you lack it, there is no software to help that.
CONVERSION: Deckel maho dmu 50m cnc
By toomast in forum Conversion Build LogsReplies: 7Last Post: 03-12-2019, 01:35 AM -
Where abouts is everyone based?
By Palletlad in forum General DiscussionReplies: 3Last Post: 25-01-2018, 01:29 PM -
Milling machine "Deckel fp2" price appraisal
By ba99297 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 08-11-2017, 12:48 PM -
uk based manufacturers
By Al25 in forum Marketplace DiscussionReplies: 8Last Post: 16-01-2013, 09:23 PM -
Anyone with a TAIG-based mill in the Birmingham/Worcester area?
By robinc in forum Milling Machines, Builds & ConversionsReplies: 10Last Post: 03-10-2011, 10:16 PM
