Re: El Beast - Initial design phase, comments and critique welcomed!
driftspin
			So ... do you dare use it? First scratch is gonna hurt bad on something as beautiful  as this.
 That's why you ALWAYS use a hammer to put it together.  Pre-empt the pain..!
Wal.
Wal
Wal.
 Hahaha best advice of  the day ! :-)
Grtz. Bert
		Hah thanks guys. Either going to anodise or powder coat, both should keep it looking nice through some gentle abuse!
Little micro update (been busy barbecuing today!)
3D printed a mount for the homing switch magnet and fitted. To set the activation range I just hooked the switch up to 24v and moved things around until the LED switched off at the right place.
https://i.imgur.com/qf3hZgV.jpg
https://i.imgur.com/ORAlUWr.jpg
https://i.imgur.com/VK3sCoM.jpg
		More work done today... Didn't have any suitable materials for the counter bearing plate so got cracking with some of the other stuff!
First up, 6mm spacer for the ball nut mount to make it reach the front plate:
https://i.imgur.com/vl4u5cu.jpg
https://i.imgur.com/0vJaVUA.jpg
https://i.imgur.com/XjENf9X.jpg
https://i.imgur.com/Gm9aicd.jpg
And then on to a big piece (so big it takes up most of my poor little X6's bed!) - the front mount plate
Externally clamped and all the interior parts done
https://i.imgur.com/PStZXgJ.jpg
external clamps removed and finished part:
https://i.imgur.com/rFPximR.jpg
Fitted along with the previously printed plugs. Other large hole will be for ball nut grease port which I'm currently working out the finer details of.
https://i.imgur.com/EP2cjwe.jpg
Full up:
https://i.imgur.com/zoTq8UZ.jpg
Full down:
https://i.imgur.com/0nuvtCl.jpg
		Decided to re-vist my original plans for a belt tensioning system.
I whipped up this design
https://i.imgur.com/ZXGArBm.png
And then set about making it. The idler I made from alu tubing which I turned down and bored out for the bearing pockets.
https://i.imgur.com/pdZFrZF.jpg
https://i.imgur.com/SUILdza.jpg
I also needed to make the upright piece which the whole assembly rolls around. Turned this from silver steel:
https://i.imgur.com/NrbJTbU.jpg
Final part that needed turning was the little rotating piece through which the threaded rod will go... Made a small jig to make sure I drilled it centrally, which could also then be flipped and guide the tap straight through.
https://i.imgur.com/vwUnAIL.jpg
https://i.imgur.com/nwabCHU.jpg
I decided to try 3D printing the main parts in the CF composite material I use for functional parts and I must admit I was amazed at just how strong it's come out. I upped the infill percentage and used extra perimeters to beef up the part even more and the result feels like it could survive being run over by a truck... my backup plan was to make the frame parts from alu plate but it won't be needed.
Even more surprising is that I modelled the M6 thread in the bearing tube mating part and it printed fully functional... didn't even need to run a tap through it. That's the smallest thread I've tried printing so far and I'm suitably impressed :)
Final bunch of parts:
https://i.imgur.com/gDYZxJ9.jpg
https://i.imgur.com/Ed7AndP.jpg
And test fitting
Untensioned:
https://i.imgur.com/qHPo4yF.jpg
Tensioned (can't fully tension for two reasons - screw thread isn't long enough, and the smaller pulley pulls in towards the bigger one without the top bearing counter plate.... but it gets the gist across):
https://i.imgur.com/0yhamwg.jpg
Pretty chuffed with that little bit of design I have to say... worked out nicely. Still need to make a knurled knob and order some m6 threaded rod to make the proper tensioner adjustment, and I also need to make the little collar that goes on the m5 standoff to help capture the rod end.
		It is very OTT but you look like you are having fun so go for it!
How about 3D printing the adjuster knob - put an internal thread in it and secure with a lock/jam nut.
routercnc
 A lot of what I do in life could be described as OTT lol...
I've done 3D printed knobs before, in fact the 3D printer is rocking one. Not quite as pretty as a nice knurled alu one though.
Zeeflyboy
 Very nice stuff, wish I had such a creative mind.
Zeeflyboy
 Its a very nice knurl you pulled off on the last one, how many goes did that take to get right? :encouragement:
		This is all looking very nice and a really wonderful build!
Would you care to share the Fusion files of the Z-axis only perhaps...? :-)
Cheers - Ard
